CPU6 Redundancy Clarification
Rav
Post by Rav »
Hi, We have two CPU6. The IP of CPU in Slot 6 is 192.168.1.3, IP of CPU in Slot 20 is 192.168.1.2 and the Role IP address is 192.168.1.1 Currently, the Main CPU is Slot 20 CPU with the IP address 192.168.1.2
Now when there power resets and the suppose both the CPU6 come on together, is it correct that the CPU with a higher IP address will become the Main. This would mean that the CPU with the IP address 192.168.1.3 becomes the main even though in Slot 6 while the CPU in Slot 20 will become the Standby.
Also the Preferred CS @IP (redundancy) is not configured as well.
If suppose, we put the Preferred CS@IP (redundancy) = 192.168.1.2, then even though Slot 20 has a lower IP address, it will always become the Main CS while then the CPU in Slot 6 with a Higher IP address 192.168.1.3 will always be the Standy-By.
Ravn
Return to “IP”
