I have an ABC-F network that has 10 nodes all on R9 and it is working ok. Now I need to add another node on R8 to the same network. R9 is Node 80 and R8 is Node 1. I have configured the hybrid link on both systems and created IP Trunk groups but suproutage shows the link changing from active to inactive. I have run incvisu on both systems and am getting the following errors:
R9:
16/07/16 09:59:12 001080M|019/00/0/028|=5:2864=PH:PLL 0 is up on Hybrid Access (1 1 Main)
16/07/16 09:59:36 001080M|019/00/0/028|=2:2868=PH:IP Hybrid Link to 1 is broken (type 2 access 1 sig Main)
16/07/16 09:59:36 001080M|019/00/0/028|=3:2867=PH:Hybrid Access (1 1 Main) goes down
16/07/16 09:59:36 001080M|019/00/0/028|=3:2865=PH:PLL 0 is down on Hybrid Access (1 1 Main)
16/07/16 09:59:42 001080M|002/22/-/---|=3:0747=Config error or Loss of IP connection: 4,(2,22),10.0.0.207,00:80:9f:aa:ca:56
16/07/16 10:00:08 001080M|019/00/0/028|=5:2862=PH:Hybrid Access (1 1 Main) is up
16/07/16 10:00:08 001080M|019/00/0/028|=3:2866=PH:Estab Req for PLL 0 on Hybrid Access (1 1 Main)
R8:
16/07/16 09:51:09 001001M|019/00/0/000|=5:2862=PH:Hybrid Access (80 1 Main) is up
16/07/16 09:51:32 001001M|019/00/0/000|=3:2867=PH:Hybrid Access (80 1 Main) goes down
16/07/16 09:51:32 001001M|019/00/0/000|=3:2865=PH:PLL 0 is down on Hybrid Access (80 1 Main)
16/07/16 09:52:04 001001M|019/00/0/000|=5:2862=PH:Hybrid Access (80 1 Main) is up
16/07/16 09:52:27 001001M|019/00/0/000|=3:2867=PH:Hybrid Access (80 1 Main) goes down
16/07/16 09:52:27 001001M|019/00/0/000|=3:2865=PH:PLL 0 is down on Hybrid Access (80 1 Main)
16/07/16 09:52:59 001001M|019/00/0/000|=5:2862=PH:Hybrid Access (80 1 Main) is up
16/07/16 09:53:22 001001M|019/00/0/000|=3:2867=PH:Hybrid Access (80 1 Main) goes down
Can anyone assist as to how I can solve the issue.
Failing to add a node to ABC-F network
Re: Failing to add a node to ABC-F network
Check hybrid link from both side:
1 - adjacent network|node (0-1 and 0-80 - if network=0)
2 - multi-access hybrid link yes/no (shall be the same - usually "yes")
3 - for PABX with duplicated CPU used IP address "main".
- mustafa.ahmad
It seems that your INTIP or GD board is not in service or has rebooted.
Hybrid link (IP) - established between CPU/CS. If INTIP/GD out of services - will be problem with voice calls but link can works (ping/telnet/broadcast etc.).mustafa.ahmad wrote:It seems that your INTIP or GD board is not in service or has rebooted.
I hope problem was solved (it was old post)
