4059 Applications 5.4.2 - Windows 10 x64Bit
TSR
Post by TSR »
Issue with 4059 Application 5.4.2
Operating System Installed Windows 10 x64 Bit
Appli : SBC Session
Msg : NOT_USED
Status : L3OPEN, l2 protocol init failed
Tried the following:
1. Firewall is turned off.
2. BIND values are all set properly
Kind regards,
TSR
ltatge
Re: 4059 Applications 5.4.2 - Windows 10 x64Bit
Post by ltatge »
First, check TechCom or Release notes. Is your operating system supported? If not, update your envoirment. Or look for an old pc wich fits 4059 requirements.
Regards LT
swinstu
Post by swinstu »
The version 5.5.2 is first compatible with Windows® 10 (64 bit), , Windows® 8/8.1 (64 bit), Windows® 7 (64 bit
& 32 bit)
Windows 10/8/8.1 accept only USB Keyboard with hardware modification: 3AK17154ABJD
Windows® 7 accept only the USB keyboards.
Compatibility OmniPCX Enterprise release R9.1 and upper.
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
oelliuromero
Post by oelliuromero »
Swinstu, how can i to do hardware modification..??
Could you help me?
Thank's
Return to “Attendant”
