Alcatel-Lucent WLAN 4306 WebUI Issue
Also known as OmniAccess Instant AP
yasirsattar06
Post by yasirsattar06 »
Hi All,
I have 2 IAPs 103-RW and one AP-105 and have one Wireless LAN Switch 4306.
I want to configure these three IAPs and APs with WLAN Switch/Controller. I configured Interface Vlan 1 with 10.1.1.250 IP for managment. When i access 10.1.1.250 from Web Browser, it asks for Login & Pass. I give Username: admin, Pass: admin, after login it shows blank Monitoring window.
Snapshot is attached for reference.
Please let me know where i am wrong and what i have to do.
dartzen
Re: Alcatel-Lucent WLAN 4306 WebUI Issue
Post by dartzen »
I have seen this problem myself a few times, it depends a bit on the firmware used. If the firmware is older (<=6.3) the internal Webserver of the OAW-Controller has problems with newer browsers. You can try using compatibility mode in Internet Explorer, which should help. I know no solution for Firefox or Chrome.
Return to “OmniAccess Wireless Access Points”
