Error when going to extensions link
L_lefante
Post by L_lefante »
I am doing a new installation. When trying to access to extesnions configuration I am getting this error:
Compilation Error
  Description: An error occurred during the compilation of a resource required to service this request. Please review the following specific error details and modify your source code appropriately.
 Compiler Error Message: CS0433: The type 'ASP.ctrl_searchextensions_ascx' exists in both 'c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\omnipcxrecord\bf79f919\3e3e33fc\App_Web_p4210vod.dll' and 'c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\omnipcxrecord\bf79f919\3e3e33fc\App_Web_fd34mgxl.dll'
Source Error:
[No relevant source lines]
Source File: c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\omnipcxrecord\bf79f919\3e3e33fc\App_Web_searchextensions.aspx.cdcab7d2.lab_f16c.0.cs    Line: 189
I am attaching a screen capture of the error. Any idea about this?
L_lefante
Re: Error when going to extensions link
Post by L_lefante »
SOLVED.
1) Stop IIS
2) Delete c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\omnipcxrecord directory
2) Start IIS
Thanks for sharing the solution :)
Return to “OmniPCX Record”
