Subscriber voicemail Not working
dcwilliams
Post by dcwilliams »
The voicemail is not working. How do I find what the voicemail number is?
Where do I set this?
Maulwurf
Re: RE: Subscriber voicemail Not working
Post by Maulwurf »
dcwilliams wrote:The voicemail is not working. How do I find what the voicemail number is?
Check you config
Maulwurf
Re: Subscriber voicemail Not working
Post by Maulwurf »
...OMC Hunting Groups
dcwilliams
I had a Hunt group 500 setup for a 3 phones. I was wondering if I had over wrote the voicemail hunt group. I changed this to Hunt Group 502 for the 3 phones. But it is still not working.
Maulwurf
Post by Maulwurf »
You need Hunt Group with your voicemail lines. Try 540.
Return to “Configuration”
