CM-1, Led Flash 5 time
hnorbi
Post by hnorbi »
Dear all,
I'm a very-very-verynewbie in Alcatel. I got a 4200e pbx. I can not found an English documentation :/ When I power up the device, the small green led on CM-1 card flashes 5 times.
What can I do?
Norbert
Re: CM-1, Led Flash 5 time
Not sure about CM-1, but for CM board from doc:
CM BOARD INITIALIZATION
When switched on the following tests are carried out :
LED FLASHING PART TESTED
1 Reset starting
2 U3 - U4 REPROM chips
3 U15 - U18 REPROM chips
4 U17 - U22 SPRAM chips
5 U19 - U20 SPRAM chips
6 MEB board SPRAM chips
7 U16 Real Time Clock chip
If the MEBXXX board is absent, there will only be 6 flashing LEDs.
In the case of successful tests, the CM board LED flashes regularly (500 ms lit / 500 ms unlit). Otherwise it
remains unlit.
I think you have problem with MEB board or with real time clock chips
hnorbi
Post by hnorbi »
Thanks! :(
Can you send the doc for me?
Link for download (Ссылка для скачивания файла): http://ifolder.su/44985744
hnorbi
Post by hnorbi »
Many thanks!
Return to “42xx Systems”
