How to configure SNMPv3 securely on ALU OS6450
alcomint
Post by alcomint »
Can someone spare sometime and help in creating an account and configure snmpv3?? :)
devnull
Re: How to configure SNMPv3 securely on ALU OS6450
Post by devnull »
user mysnmpv3user password SNMPPASS123 read-write all sha+des
aaa authentication snmp local
thats all that is needed to access the switch with snmpv3 with the user "mysnmpv3user" and password "SNMPPASS123"
(Password has to be at least 8 chars otherwise snmpv3 will silently fail)
alcomint
Post by alcomint »
Thanks devnull, I am trying to access the switch through linux but I am failing again and again. how can I do that?
alcomint
Post by alcomint »
I actually have configured snmp without authentication:
status community string user name
enabled private npprivate
enabled public nppublic
When I am trying to snmpwalk at cents terminal
snmpwalk -Os -c public -v 2c 178.13.240.48
Timeout: No Response from 178.13.240.48
snmp v3 without authentication? not possible.
but your command snmpwalk shows the answer: you use snmp v2
than try this one:
> user OV-READ password OV-READ-PW read-only all no auth
> snmp community map public user OV-READ
> snmp security no security
Return to “OmniSwitch 6450”
