7750 emulated on PC?
bdnhsv
Post by bdnhsv »
Hi everyone. Can the 7750 image be hosted on a PC based server? I ask because I ran across a device appearing as a 7750 that has TCP ports 135, 139 and 445 active. The timos image is c10.0.r5. Thanks for your feedback.
thecandymancan
Re: 7750 emulated on PC?
Post by thecandymancan »
you probably can, alu have been running sims on pcs for a while but I've never seen it in the wild. The only official release is from SROS VM from release 12 up.
bdnhsv
Post by bdnhsv »
Thanks candyman. This device is definitely in production.
lo0
Post by lo0 »
Yes, you can drop it in GNS3 a well. However, it will reboot every hour without a valid license... good news is that you can save your configuration.
Stoffen
Post by Stoffen »
lo0 wrote:Yes, you can drop it in GNS3 a well. However, it will reboot every hour without a valid license... good news is that you can save your configuration.
Not with
[flash=]
Christoffer
Network System Expert Norway
Nokia SRA #265
Cisco CCNP Certified
LinkedIN
[/flash]
thecandymancan
Release 10 doesnt reboot or release 10 doesnt work in GNS?
Stoffen
Post by Stoffen »
thecandymancan wrote:Release 10 doesnt reboot or release 10 doesnt work in GNS?
As far as I know, it does not work.
No x86 images on the open marked.
I know, as you said as well, there is some special x86 systems running at Nokia LAB's.
When I asked Nokia about that in Antwerp a few years ago, they claimed it needed special PCI cards to run on x86 platform.
But hell, I've been wrong before :)
[flash=]
Christoffer
Nokia SRA #265
LinkedIN
[/flash]
rasputinlv
Post by rasputinlv »
did anybody run release 14 VMs?
I cant get to configure mode or run any show commands? is something wrong with my VM, or I'm missing something?
Thanks an advance.
cisco001
Post by cisco001 »
rasputinlv wrote:did anybody run release 14 VMs?
Thanks an advance.
I have the same issue, i cannot see configure command on vSROS 14 R1 and R2.
Anybody know how to fix this...
lo0
Post by lo0 »
The latest vSR release that works for me in GNS3 is 13.0.R4. I'll try 14.0.R1 today.
Return to “7750 SR”
