40key AOM malfunction in 8038
jongbam1
Post by jongbam1 »
There is a problem in using 40keys AOM(3MG27106AB) to 8038(Power of Lan).
The same config existing 40x8 series module is the key does not work.
Other products also, the same.
Add On Module 1 + 40 Keys x
x Add On Module 2 + None x
x Add On Module 3 + None x
x Internal Alphanum.Keyboard + English x
x Called Associated DECT set : -------- x
x Dial by name and text msg. + NO x
x Text msg number : 8
lqReview/Modify: Progr.Keysqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Directory Number : 2743 x
x Key No. : 75 x
x x
x Function + Programmed x
x Mnemo (Pocket,Mobile,4040,8&9) : -------------- x
x UTF-8 Mnemo (8&9 Series) : ------------------------------- x
x Content : 901038250656 x
x Locked + NO x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
OXE 'S Version is R10.1.1-j2.603-38
Is version issues or do the other settings?
Please advice.
Thanks.
L_lefante
Re: 40key AOM malfunction in 8038
Post by L_lefante »
What is the problem?
jongbam1
Post by jongbam1 »
The problem was solved.
I was malfution because they use a regular SATA cables.
Should use the SATA cable that is included.
L_lefante
Post by L_lefante »
Thanks for sharing the solution!!!
Return to “Alcatel-Lucent Series 8&9”
