I would like to apply for ACFE/ACSE certifications. However, I can't find any documentation for studying this kind of certification. I've found NRS1 and NRS2 books but it is for service routing instead of switching.
Where can I buy a book about omniswitch for this certifications?
Best regards.
ACFE/ACSE Certifications
- cavagnaro
Re: ACFE/ACSE Certifications
You first have tô be a parter, a freelance doesn't have access go these certifications. Then your employer goes and buy the training, then you can go for certification.
Thanks Cavagnaro,
OK,ok ... I see it's difficult to have information for learning this kind of switches. I don't work for a partner but for a final customer. I thought there was some book about omniswitches.
Thanks, best regards.
lol, what are you talking about?!
I got two books, took the online exam and that was easy. acfe6/7.
Not sure about data equipment but for telephone system was not a problem with ACFE certification.
Ask ALU partner in your region. If you have experience - I think this is small course + online exam.
For ACSE - another story - for telephone equipment it was 2 week course + class room exam.
- cavagnaro
ACFE? Yes, as end user maybe. But not ACSE as you need to build a full lab system.rekeds wrote:lol, what are you talking about?!
You got the books from who? A BP or ALU directly?
The ACFE can probably be solved using a sane mind and some basic lineup knowledge.
ACSE is with lab and way harder
dears
iam trying to connect two oxe system with ABC-F and i couldn't
need some helpful documentation for that please
thanks
thanks
