headphone for 408/40s9
Sam2009
Post by Sam2009 »
Hi all
I am configuring Call Center, and Agent set are IP-touch 4028 which has socket for connect headphone.
My customer want to connect headphone for answering calls instead of handset.
i try to connect headphone , i can hear the caller's voice but he didn't hear any thing.
is there any thing I have to do???
Please could any one advise me.
thanks
Re: headphone for 408/40s9
Create the headset key?
Sam2009
Post by Sam2009 »
hi cava
i create headset key , same issue
i can hear , but the other side can't hear any thing until i use handset of the phone
is there special type of headphone to use???
Sam2009
Post by Sam2009 »
hi cava
You are using which headset? A RJ11 connector, right? Not a 3.5mm jack
Can be some problem:
1) wrong headset (jack contacts - like Apple and Samsung have different contacts order).
2) in set menu can be programmed headset output assignment (not sure about 4028)
Sam2009
Post by Sam2009 »
I want to use audio jack 3.5mm to connect external Headphone.
i test it with 4038 and same issue.
Sam2009
Post by Sam2009 »
Which type of 3.5mm jack i must use
kindly see attached file
Sam2009
Post by Sam2009 »
I think it won't work as you desire.
I do remember doing tests years ago and behavior was not the same as a headset. It is just an auxiliary audio exit.
You need to use a RJ11 one.
Return to “Alcatel-Lucent Series 8&9”
