problem with imap and 4645
alexeik
Post by alexeik »
i have a cutomer who wants an imap mailbox within his 4645. we bought a license and installed it. Then i altered a voice mail category for imap=yes and changed the users category. if i try with an imap client i get wrong user or password.
Then i looked at the imap menu in swinst, and it says "imapd cannot run on this cpu". It is the right cpu, i doublechecked it. There are also several imapd tasks running. Anyone an idea how to solve this?
Release is 11.0.1 k152034
greets alex
tgn
Re: problem with imap and 4645
Post by tgn »
imap in swinst is only in use when you'll need an extra external imap server.
try to use imap by telnet.
telnet emailserverip 143
username is mailboxnumber (=telephonenumber)
password is mailboxpassword (!=telephonepassword)
regards...
alexeik
Post by alexeik »
hmm in our system here swinst says
Actual Configuration
Imapd service is present (it is started on RUNTEL)
VIMAP CPU List
4645 : localhost
Press Return Key To Continue
but at the customer
Imapd service cannot run on this CPU
VIMAP CPU List
4645 : <no cpu>
when i try with telnet
(101)xa001001> telnet localhost 143
Trying 172.20.3.152...
Connected to xa001001.
Escape character is '^]'.
* OK [CAPABILITY IMAP4REV1 AUTH=LOGIN AUTH=PLAIN] xa001001 IMAP4rev1 at Fri, 23 Oct 2015 08:12:30 +0200 (CEST)
and then nothing...
tgn
Post by tgn »
which cpu type?
regards...
alexeik
Post by alexeik »
cs-2...
Return to “My Messaging / IMAP”
