I have the following Series IP Touch 4068, 4028, 4018. The company has canceled Alcatel headquarters. Now I would like to connect these phones using SIP. I found the necessary configuration files, launched the TFTP but according to my logs file is missing bin4068G 4068 to 4028 my file is missing bin4028, 4018 I have not tested. I was one of the Internet, but I have never found such files.
Is it possible these phones connect to external SIP headquarters without it was a core of Alcatel?
Can you give me some advice how I could start?
Do you know someone send me these bin files?
thank you
Michael
Connection to SIP for 4068, 4028, 4018
Re: Connection to SIP for 4068, 4028, 4018
You can use Asterisk. The tftp is needed to load new binary to the phone. Is a must.
Enviado de meu C6602 usando Tapatalk
zvukarmiso
I use Asterix
I found the configuration files. But TFTP log lists the following errors.
Where did I take those files?
I would not like throws the phones are SIP and I think it could go.
Can you please upload those files?
Connection received from 192.168.1.7 on port 1024 [02/09 10:03:03.185]
Read request for file <noesip4068G-header>. Mode octet [02/09 10:03:03.185]
File <noesip4068G-header> : error 2 in system call CreateFile System can not find the file specified. [02/09 10:03:03.187]
Connection received from 192.168.1.7 on port 1024 [02/09 10:03:03.190]
Read request for file <noesip4068G>. Mode octet [02/09 10:03:03.190]
File <noesip4068G> : error 2 in system call CreateFile System can not find the file specified. [02/09 10:03:03.191]
Connection received from 192.168.1.7 on port 1024 [02/09 10:03:05.191]
Read request for file <bin4068G-header>. Mode octet [02/09 10:03:05.191]
File <bin4068G-header> : error 2 in system call CreateFile System can not find the file specified. [02/09 10:03:05.191]
Connection received from 192.168.1.7 on port 1024 [02/09 10:03:05.194]
Read request for file <bin4068G>. Mode octet [02/09 10:03:05.195]
File <bin4068G> : error 2 in system call CreateFile System can not find the file specified. [02/09 10:03:05.195]
