To View Timers without going into mgr
Dave_DUP
Post by Dave_DUP »
use the command tabtemp after the command enter the timer number you want to view the value of. If you just enter the command you will see all the timers and the values. Also give a brief description of the timer.
Return to “Usefull commands”
