Hi all,
my customer Z32 board is break down and need to replace it. it is difficult to find a board in the market. I only find eZ32 board.
Is it possible to use EZ32 and user license to replace Z32?
Eric
what is difference between Z32 and eZ32
Re: what is difference between Z32 and eZ32
yes, if oxe software release support ez32.
also like you say: you have to buy 32 analog user licenses.
the ty1 system cable connection is the same for both interface cards.
regards...
regards...
Usually no. In Release before 5 Lx - cannot be used eZ32.
If system was migrated you will have problem with licences - for Z32 used "202 Migration analog user" and for eZ32 "174 Call handling: Analogue users".
Customer currently using eZ32 card and they upgrade their system to release 11. Can they use Z32 card instead of eZ32 ?
As I remember - Z32 more expensive, why you want use them? Usually Z32 board - old/used.
In additional for user on Z32 board used another lock - not 174 but 202 Migration analog user.
In another words - you can use (with some condition) but you shall understand - why you need this.
some of the older z32 boards cannot spent callcenter features to noe telephone sets.
regards...
regards...
There is no eZ32 cards available in Australia. I can get only Z32 cards at the moment. Customer is fully aware about that the card is more expensive and it loaded with licenses.
plise translet to enggris
untuk sparpat alcatel omi pcx interpres saya ada di toko sya di indonesia harga terjangkau jangan ragu untuk membeli dan bertanya kami amanah untuk kerjasama nya terimakasih
here the english text from Teguh Santoso :
for alcatel omi pcx interpret sparepart i have it in my shop in indonesia affordable price don't hesitate to buy and ask we are trustworthy for cooperation thank you
