6900 reload queery
stunshot
6900 reload queery
Post by stunshot »
Can anyone answer if I have a 6900vc, all fully sychronised, running from vc_dir, if i issue a reload will it come back in vc_dir or certified, I seem to recall there was an issue where it comes back in cert ??
Re: 6900 reload queery
If you use command, than it is not possible to say only "reload". You have to choose the directory "reload (chassis...) from vc_dir no rollback-timeout".
After power down it depends from certification state of your running-directory (vc_dir). In your case is all certified so it will come back from vc_dir.
Return to “OmniSwitch 6900”
