simple LLDP policy for phones
stunshot
Post by stunshot »
Hi all, any advise on a simple LLDP policy for voip phones to automatically pick a voip vlan (vlan 200)
Re: simple LLDP policy for phones
vlan 200 enable name „voice“
vlan 200 mobile-tag enable
vlan port mobile 1/1-24
lldp network-policy 1 application voice vlan 200 l2-priority 5 dscp 46
lldp network-policy 2 application voice-signaling vlan 200 l2- dscp 30
lldp chassis tlv med capability enable network-policy enable power enable
lldp chassis med network-policy 1 2
slixxboy
Post by slixxboy »
are these applicable to any brand of ip phone except alcatel ip phone?
yes
Naritaokaza
Post by Naritaokaza »
Get to know a lot can actually be used.
Reginaldo
Post by Reginaldo »
Hello Silvio.
I'm new here, but I've already followed your guidance on several issues.
I have the same question as Stunshot about how to practically configure the use of a telephone and computer on the same switch port.
It turns out that I use the Alcatel OS6560, these commands that you mentioned are not compatible with it.
Could you please guide me on how to do the same configuration on the Alcatel model: OS6860E-U28, firmware: 8.9.107.R02?
Grateful.
It will be fine if you ask your question in the correct section for your switch - not in such old one.
All AOS R8 switches use the same config f.e. 6360, 6465, 6560, 6860.
Without lldp-med you can use the answer in https://www.alcatelunleashed.com/viewto ... ne#p112688.
For lldp you use the same lldp commands like for the R6 switches (f.e. 6400) and as classification rule one with lldp. Your phone profile needs to be "mobile-tag".
Return to “OmniSwitch 6400”
