If the user has a missed call, the message button is flashing. Is it possible to disable this? So the user isn't notified when he has a missed call?
Disable alert missed calls
Re: Disable alert missed calls
isdn internal user == false does it for internal calls.
regards...
regards...
What you want to solve - disable missing calls information or stop LED flashing?
For disable missing calls - User - ISDN subscriber item - you can disable access to unanswered calls (External or Internal).
Read system doc - /System doc/ User Services/ Unanswered Calls
telco1
Yes actually i want only to disable the flashing LED, is this possible?
yes it is...tgn wrote:isdn internal user == false does it for internal calls.
regards...
regards...
Case from my practice - customer open telephone set and painted Message button by dark paint.
^^ or you can just use the force and say "this is not the message light you are looking for!" ^^
may the might be with you
regards...
regards...
