Vlan limit flat stp/mstp
stunshot
Post by stunshot »
All,,,have a 9000 chassis running flat stp and mstp. I belive the vlan limit is 4094 (as it running flat stp) but am getting an error when adding any vlan after the 252 1x1 limit. This doesnt sound correct, anyone seen similar ??
Re: Vlan limit flat stp/mstp
In BoilerPlate for the 9000 I have found the following:
Up to 4094 VLANs can coexist when running in Flat STP mode and 252 in 1x1 STP mode.
rekeds
Post by rekeds »
disable stp for your next vlans
devnull
Post by devnull »
i always have e bad feeling when i see a disabled stp.
rekeds
Post by rekeds »
hehe, if switches is all you got, yes, I could agree that a meltdown will happen.
