portfast in mini 6400
chuikingman
Post by chuikingman »
I think there is something like portfast or fastport for Spanning tree in omni switch 6400.
what command I need to use to config this ..??
Could you advise in detailed ???
thank
Regard/chui king mamn
Re: portfast in mini 6400
You didn't need this with RSTP (default at all omniswitches).
Portfast is like edgeport. Default all ports are configured with auto-edge. So only if bpdu are received at a port than the port will change to ptp.
you can change it with:
> bridge <VID> 1/1 connection edgeport
but mostly this isn't necessary.
daac84
Post by daac84 »
Hey there
I'm just testing, I have a 6450 and I am trying to configure portfast, but by entering the command
# bridge 17 1/1 connection ?
PTP NOPTP AUTOPTP
solo salen las opciones de ptp noptp , hice la prueba y veo que cuando seleccion noptp se demora mas en pasar en estado fw con show spantree ports , por que pasa esto si se supone que noptp seria como un edge port
otra duda saben como puedo configurar un umbral de tormenta de broadcast ??
just out ptp options noptp, I auditioned and I see that when noptp selection takes longer to happen in fw state spantree show ports, by passing this if it is assumed that as a serious noptp edge port
other question I know how to configure a broadcast storm threshold ??
in cli guide 6.7.1 this is written at the bridge connection command:
edgeport: This parameter is currently not supported. Use the bridge cist slot/port admin-edge or bridge cist slot/port auto-edge command to configure edge port status.
I have used the other command in older releases.
Also in Cli guide you will find answer for flood control:
interfaces 1/3 flood broadcast rate pps 500
Return to “OmniSwitch 6400”
