No dialing tone
ts4488
No dialing tone
Post by ts4488 »
after setting up an ancient Office 4200D there seems to be an issue on Reflexes extensions with a display.
There is no internal dialing tone present when the receiver is lifted or speaker button is pressed - quite irritating to any user.
Any simple phone (e.g. 4003) or analogue line works just fine.
Interestingly the tone is present when a 4003 was connected to the port previously and is replaced by a 4034 etc.
System software is 3EH302445DWAA D/DE420/43.1A
Is there a siple fix to this issue (new firmware)?
Thanks,
Tristan
Maulwurf
Re: No dialing tone
Post by Maulwurf »
Change CM Adress DialToMult to 01
ts4488
Re: No dialing tone
Post by ts4488 »
Where can I modify this setting?
I've been working with Siemens for many years, Alcatel is new to me ;)
ts4488
Re: No dialing tone
Post by ts4488 »
I've just found it!
Works fine!
Re: No dialing tone
By mistake I disapproved your last message, please post it again.
Sorry for the inconvience
ts4488
Re: No dialing tone
Post by ts4488 »
Actually there are two more questions (if necessary move it to another thread).
a) Is there a way to show the extension no. permanently in the display (as on the previous 4210 PBX)?
b) Why do internal calls have no MOH but a nasty signal tone?
Re: No dialing tone
In 4200/OXO - not possible to use MOH for internal calls placed on hold.
Return to “42xx Systems”
