Problem with the lateral tonne in A4200E
jimgkatzias
Post by jimgkatzias »
I would like your help with a A4200E.
Is in operation and hold: 1 x DLC, 5 x SLC8, 1 x SLC4, 1 x SOTO 8, 1 x SOTO 4.
Past 6 months after a major blackout appeared in place of side tone a strange sound is like rain, after 2 days however came back, has now been 10 days that continues this sound, replaced power supply. Supplying the problem remains to note that all other functions have no problem except when you lift the handset you hear me up in response to hear that the rattling noise.
Has anyone on the problem, how deal with it?
I doubt anyone has currently that problem as that platform is very very old and no longer in support. Maybe a capacitor has a leak or a short cut somewhere..
Friday
Re: Problem with the lateral tonne in A4200E
Post by Friday »
It might be a blind shot, but try to replace the handset.
I have seen before that a defect handset can produce strange sounds.
jimgkatzias
Friday wrote:It might be a blind shot, but try to replace the handset.
Understand the problems created by a device, we noticed that some old tech devices not ringing, while the PBX routes the call, the device does not ring and if you lift the handset reply normally.
Again...voltage for ring is supplied by....no, not the air...no, neither the magic nor the force...
yeah...boards
And boards have electrical components which on time....yeah...degrades...
So...what you think
yeah...boards
So...what you think
murraya
Post by murraya »
i think you got a stutter cav.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
jimgkatzias
cavagnaro wrote:Again...voltage for ring is supplied by....no, not the air...no, neither the magic nor the force...
yeah...boards
So...what you think
If I understood sense of being somewhere boards, yes but from what? the AC-1? CM-1? SOTO8? SLC8?
jimgkatzias
murraya wrote:i think you got a stutter cav.
Sorry ....
I did not get it (stutter cav)
murraya
Post by murraya »
hi I meant because he repeated his answer.
maybe the attached will help? dug it up from my old archives.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Return to “42xx Systems”
