Automatic off-hook dialing (hotline) issue
soilun
Post by soilun »
Hi all,
I'm provisioning hotline feature on OXE R11. Document tell me go to "Categories > Phone Facilities Categories". But from my mgr, I can't find where "Categories". What wrong with my OXE or I need active something more?
lqSelect an objectqqqqqqqqqqqqqqqqqk
x x
x -> Shelf x
x Media Gateway x
x PWT/DECT System x
x System x
x Translator x
x Classes of Service x
x Attendant x
x Users x
x Users by profile x
x Set Profile x
x Groups x
x Speed Dialing x
x Phone Book x
x Entities x
x Trunk Groups x
x External Services x
x Inter-Node Links x
x X25 x
x DATA x
x Applications x
x Specific Telephone Services x
x ATM x
x Events Routing Discriminator x
x Security and Access Control x
x IP x
x SIP x
x DHCP Configuration x
x Alcatel-Lucent 8&9 Series x
x SIP Extension x
x Encryption x
x Passive Com. Server x
x SNMP Configuration x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
tgn
Post by tgn »
classes of service == categories
regards...
Re: Automatic off-hook dialing (hotline) issue
mgr -l GEA
soilun
Post by soilun »
cavagnaro wrote:mgr -l GEA
Great! thank you very much cavagnaro :)
soilun
Post by soilun »
tgn wrote:classes of service == categories
regards...
Thank you tgn :)
jdaguarino
Post by jdaguarino »
Hi cavagnoro,
I use the command mgr -l GEA and the categories is now appearing. My question is what command that i will go back the class of service from the mgr menu?
Thanks in advance
What?
I hope you understand what you want to do? F.e. if you want - hotline for some people.
- you need to manage Phone feature COS (categories) not used by another users
- you need to declare this COS (categories) in user parameters
if you just change categories 0 - you manage hot-line for all users.
Return to “Users”
