OXO with T38 fax Gateway
ceffoudou
Post by ceffoudou »
I would like to use an M - ATA SmartNode as t38 fax gateway with the OXO in R10.
Does someone among you, has experienced the operation?
Merci beaucoup pour votre réponse.
matiyat
Re: OXO with T38 fax Gateway
Post by matiyat »
hi..
i faced same problem.
i can't received or send fax thru ATA.
please any special configration on ATA or OXO R10.x
Br
Lets see...
OXO -> Analog -> T38 -> ATA -> SIP -> T38 on other side.
How can this be an OXO issue? Check your ATA configuration and medium used. You can't compress on T38, need G711 or as much as G729 with a good link.
Return to “Configuration”
