can't possible to reach enterprise directory from 4019
mistof_44
Post by mistof_44 »
We have some problem with 4019. In fact, we don't have any access to the enterprise directory from these phones.
We have a OmniPCX 4400.
On the 4019 manual, it indicates that it's possible to see the enterprise directory.
I see some information that this issue is just possible on OXO...
Could you confirm this information please?
On my side, I find strange that it's possible on OXO and no by OmniPCX.
Thank you.
Re: can't possible to reach enterprise directory from 4019
Depends on the license bought: standard or advanced for IP sets I think.
mistof_44
Post by mistof_44 »
Thank you for your reply.
We have just UA phones (4019) and no IP phones. But if I understand that, it's necessary to have the good licence. However, the others phones(4029, 4039, 4035...) can make searches call by name.
Thank you.
tgn
Post by tgn »
4019 and 4018 can't use the dial by name function with OXE software. reason is that there are completely different teams responsible for software in OXO vs. OXE world.
regards...
Turlupin
Post by Turlupin »
There is no keyboard en 4018/4019 sets ...
Sorry for my english .... :)
Lol last answer seems to be winner
tgn
Post by tgn »
[kidding mode]i am an expert... sometimes i feel like drawing transparent lines. you can't see them but they are there... maybe on OXO this tiny little 4018/9 becomes a keyboard. but it was just drawed with transparent ink. and also i think the 4018/9 is getting transparent wings if you connect it to the OXO ;) [/kidding mode]
regards....
Actually I know it is possible what he asks. I do not know exactly what needs to be enabled but is should be the dial by name on user features I guess.
Regarding my first post in your case I was referring to Advances reflexes users license (lock 173) against Standard reflexes license (lock 316).
The presales engineer has the opportunity to reduce the price of the solution by choosing standard licenses:
Series 9 (4019) Standard Licences
This is quote from Actis:
The restrictions as regards the Business licence are:
- up to 2 lines: one directory number with 2 lines or 2 directory numbers with one line per number
- No set or trunk supervision
- Does not belong to a Boss/secretary set
- Does not belong to an MLA group
Note: call by name cannot be associated with a standard licence
Oh yeah tot, but without keyboard, how he can search by name?
Like an oldy 4010, digital but can't use some features.
tgn
Post by tgn »
original text from 4018/9 userguide:
Using call by name*
long press of phonebook button
You enter your contact's name in predictive text mode. In this mode, enter each letter of
the name by pressing only once on the key with this letter.
* Depending on your telephone system, contact your installer or consult the appropriate User Guide.
so it work in this way on OXO but do not work on OXE.
regards...
Return to “Users”
