Configuring 8012 in OXO
Xero
Post by Xero »
I am trying to configure 8012 IP phone in OXO, but I am unable to do it. How ever all my 8028 and 8038 phones got registered and working fine.
Can anyone help me? or suggest a solution?
Konstantinos.E
Re: Configuring 8012 in OXO
Post by Konstantinos.E »
the easiest way is to setup a dhcp from your oxo for alcatel devices..
or an other way is to read the manual..
Is not the same as 8028 and 8038.. those are noe.... 8012 is sip device
Alca_holic
Xero
Post by Xero »
Thanks Konstantinos,
We have to use the DHCP from the network, anyhow I have managed to configure the sets on static IPs, the difference as these are SIP phones their D/L port and D/L directory for binaries are different 10443 & /dmcfg/ respectively.
Still want to know the way to configure these phones using network DHCP.
Check documentation and search the forum please. There are many posts with same questions
Xero
Post by Xero »
Hi cavangaro,
I would appreciate if you could give the link of the posts, I have searched the forum and am unable to find it. Thankyou in advance.
Return to “Configuration”
