PCS UNDEF, pcscopy failed
soilun
Post by soilun »
Hi all,
I have CS and PCS in my topology. From my CS, I can ping to PCS. But the status on CS when I show pcsview as below:
| PCS Name | Address | State | Reset Type |
| ps1c-e-c1-pcs01 | 172.30.8.13 | UNDEF | Default (30s) |
| ps2c-e-c1-pcs01 | 172.30.108.13 | UNDEF | Default (30s) |
When I do pcscopy, the status as below:
PCS Database Update => End NOK: Copy on PCS failed
/etc/hosts file on CS:
10.253.253.2 xb000000
10.253.253.3 xma000000
10.253.253.4 xmb000000
10.253.253.10 adm000000_1
10.253.253.11 adm000000_2
10.253.253.20 app000000_1
10.253.253.21 app000000_2
127.0.0.1 loopback
192.168.11.5 xa000000
255.255.252.0 subnetmask
172.30.8.1 ps1c-e-c1-rou01 defaultrouter
172.30.108.1 ps2c-e-c1-rou01
172.30.8.11 ps1c-e-c1-ippbx01 localhost
172.30.108.11 ps2c-e-c1-ippbx01 standcpu twincpu_eth twincpu_best
172.30.8.12 cpu01-main maincpu node000000 localmain
172.30.108.12 cpu02-main twinmain
172.30.8.13 ps1c-e-c1-pcs01
172.30.108.13 ps2c-e-c1-pcs01
/etc/hosts file on PCS:
192.168.11.1 xa000000
127.0.0.1 loopback
172.30.8.13 ps1c-e-c1-pcs01 maincpu standcpu node000002 localhost
Please give me some advices on this case.
Thank you very much
tgn
Post by tgn »
does it work before the issue?
regards....
oldboy
Re: PCS UNDEF, pcscopy failed
Post by oldboy »
When you do a pcs copy is the TEL stopped on the PCS?
soilun
Post by soilun »
@tgn: it not worked before.
@oldboy: the TEL started on PCS when I do pcscopy.
thank you guys for reply
sylvainsjc
Post by sylvainsjc »
Can you try this on the CS main connected with mtcl :
rcp /DHS3dyn/BACKUP/IMMED/pcs swinst@IP_PCS:/DHS3dyn/BACKUP/IMMED
ACSE OmniTouch CCIVR (2014/05)
ACSE OmniPCX Enterprise R11 (2013/12)
ACSE OmniTouch Contact Centers Standard Edition (2013/11)
ACSE OmniPCX Enterprise R10 (2012/06)
ACSE OmniTouch Contact Centers Outbound R10 (2011/06)
oldboy
Post by oldboy »
Stop the TEL, create a empty database, then do a PCS copy..
one other note is the software version on the CS and PCS the same?
soilun
Post by soilun »
It's already fixed, sorry it's my fault. I added host file via Linux instead of using netadmin tool.
Thank you very much, guys
Return to “Passive Communication Server”
