VRF
iladminho
VRF
Post by iladminho »
Hello, I have a problem with setting vrf on 6850E. I created vrf "one" and then use vrf route leak to add route in vfr default and vrf one. When I use command show, I see that routes are in routing table vrf default and vrf one, but I cannot ping or telnet vrf default from vrf one. Do you have any ideas why it happens?
-> show vrf
Virtual Routers Protocols
default
one
interface vrf default ivlan100 100.1.1.1 255.255.255.0 UP YES vlan 100
interface vrf one ivlan110 110.1.1.1 255.255.255.0 UP YES vlan 110
-> show ip route-map
Route Maps: configured: 2 max: 200
Route Map: Rimport Sequence Number: 50 Action permit
match ip-address 110.1.1.0/24 redist-control all-subnets permit
Route Map: Rexport Sequence Number: 50 Action permit
match ip-address 100.1.1.0/24 redist-control all-subnets permit
one::-> show ip route-map
Route Map: Rexport Sequence Number: 60 Action permit
-> show ip global-route-table
Total 2 routes From All VRFs
Export VRFName Dest Address Subnet Mask Gateway Addr Metric Tag
default 100.1.1.0 255.255.255.0 100.1.1.1 1 0
one 110.1.1.0 255.255.255.0 110.1.1.1 1 0
-> show ip route
+ = Equal cost multipath routes
* = BFD Enabled static route
Total 3 routes
Dest Address Subnet Mask Gateway Addr Age Protocol
100.1.1.0 255.255.255.0 100.1.1.1 00:02:05 LOCAL
110.1.1.0 255.255.255.0 110.1.1.1 02:06:42 IMPORT
127.0.0.1 255.255.255.255 127.0.0.1 06:22:04 LOCAL
Total 3 routes
100.1.1.0 255.255.255.0 100.1.1.1 00:02:18 IMPORT
110.1.1.0 255.255.255.0 110.1.1.1 06:02:13 LOCAL
127.0.0.1 255.255.255.255 127.0.0.1 06:08:05 LOCAL
pstolpe
Re: VRF
Post by pstolpe »
Did you find a solution to this?
I have the same issue and have tried to find the missing part...
pstolpe
Re: VRF
Post by pstolpe »
I have got a confirmation that ping replies to local interfaces on the router (the gateways) between VRFs will not function in current releases as of todays date.
But leaking works and you can ping from client to client.
