CPU spikes
doctora
CPU spikes
I have been receiving snmp traps about cpu crossing above threshold. I am looking for ideas on where to start looking into this. Thanks in advance for any ideas.
devnull
Re: CPU spikes
snmp requests?
All that must be handeld by CPU, can be responsible:
- snmp requests,
- stp handling
- multicast
- ARP handling
if you have longer spikes you can try to analyze in dShell.
>dshell
Working: [Kernel]->spyMax=3
spyMax = 0x55f5c4: value = 3 = 0x3
Working: [Kernel]->
------- SPY TOP TICK USAGE -------
task ticks: taUdldNi 36
task ticks: tShell 13
task ticks: bcmL2X.0 8
idle total: 373 500
task ticks: taUdldNi 22
task ticks: bcmL2X.0 9
task ticks: taVmnCtrl 7
idle total: 377 500
spyMax=0
spyMax = 0x55f5c4: value = 0 = 0x0
- snmp requests,
- stp handling
- multicast
- ARP handling
>dshell
Working: [Kernel]->
idle total: 373 500
idle total: 377 500
spyMax=0
doctora
Re: CPU spikes
Sorry it took me so long to get back to this. The spikes are not service effecting but they bug me.
Thanks for everyones input
rekeds,
read logs - nothing in swlog except me logging in and out,
monitor utilization - nothing strange except the CPU spikes
disable debugs - How do I know if debugs are on?
devnull
I was monitoring the switch with whats up gold. I deleted the device to see if the SNMP requests were contributing. No Change still getting spikes
I am a novice and I dont know what the rest means. I will look some of it up but I probably wont venture into the dshell.
To all that are reading this.
So far I did add the switch to an old version of Omnivista so I could use the statics to time the spikes and then I used port mirroring to catch all the data and pinpoint the time of the spikes. I was hoping to see a bunch of SNMP data but I did not. I am not sure what I should be looking for but I will keep looking and report what I find and how I found it.
It has been running for 208 days. Does anyone think that it could need rebooted? It would tick off some clients but I am in IT so I am fairly used to ticked off clients.
Thanks again for any feedback
Mark
rekeds,
devnull
Mark
rekeds
Re: CPU spikes
we had cpu spikes with the ipv6 long packet bug.
but it was fixed some time ago.
debug ipv6 set ipv6ControlProtocolDisable 0 this helped in my case.
but the cpu 100% was for few hours and wouldn't drop.
are you the only one who can access the switch?
maybe somebody is doing something nasty to it, like scanning, bruteforcing, but that should be in logs.
we have about 80-100 omniswitches, from time to time one of the 6400s goes to 100% and then drops down, but that hasn't bothered me that much as its once a month and I was not able to determine why they do it, we don't use any l3 features also.
matteonasi
Re: CPU spikes
same problem here. all of the 6450 are "soffering" CPU spikes on random bases during working hours. I could only notice that on some device things are fine without vlan port mobility enabled, but I wouldn't say that's the problem. Same config into 6850 devices without any issue.
tried different 6.6.3 and 6.6.4 AOS versions without any difference.
pretty difficult to find out.
any more idea ?
any more idea ?
- thermseeker
Re: CPU spikes
After almost 4 years, any conclusions on this? I keep getting SNMP traps on CPU and Rx/Tx thresholds crossing up, and after a few seconds another trap crossing down.
