Hi, i have an OXE in R10.1.1. Can i change the call identification in a forward call? I explain it. I have an extension that is forward to a mobile, when i receive a forwarded call in the mobile the call identification number is the direct number of the forwarded extension, i want that the number display in the mobile will be the original calling number not the forwarded calling number.
Regards.
Forward identification
- cavagnaro
Re: Forward identification
Search the forum
Short answer: Depends on your carrier
Hi cavagnaro, I know that there are a parameter where we can say witch identification i send to the carrier but a don't know where is. Then, of course, the carrier should acept this number. In a t3 traces i see that i send the forwarded number not the original number.
Hi cavagnaro. In a t3 trace i see that i send to the carrier the forward number not the original number, i know there is a parameter to modified this but i don't know where.
System/ other system/ external signaling param. - item "NPD for external forward".
In additional for external calls (when calling user - external) - you can play with "Call diversion" feature.
Hello Vad,
What value should the "NDP for external forward" be set to?
the number of npd that you configured for external forwards.
regards...
regards...
OK I now just discovered the attribute help in the right hand pane of the 8770 NPD Numbering Plan Discription OK got it so if dialing 0 for external calls change the "NPD for external forwards" to 0 and the callers ID should be passed on when forwarding externally.
Many thanks VAD & tgn.
