Help to make cable to connect the pc with a 4200E
jimgkatzias
Post by jimgkatzias »
Hello
I would like Help to make cable to connect the pc (com) with a 4200E
tgn
Re: Help to make cable to connect the pc with a 4200E
Post by tgn »
jimgkatzias
ok not understood by coincidence i first is DB9 and the second at 10 pin X7 in the Χ8
tgn
Post by tgn »
yes... complete pinout of the 10 pin burndy ->
http://www.aggsoft.com/pbx/alcatel-4200.htm
Pin Signal Function
1 REMOTE Signal used for remote access
2 RXD 104 - Reception
3 TXD 103 - Transmission
4 DTR 108 - Data Terminal Ready
5 GND Ground
6 DCD 109 - Carrier Detection
7 RTS 105 - Request To Send
8 CTS 106 - Clear To Send
9 GND Ground
10 SGND 102 - Signalling Ground
regards...
jimgkatzias
Thanks.
The ball was connected, upload a photo with the shape for which the need.
[img]
[/img]
Return to “42xx Systems”
