Can anybody help me to create Suite setup for a hotel environment.
i have two IP extensions and one analog phone for the bathroom .client need room number to dial all three extensions and also same number preferred for PMS checking. Pls. advice on Suite kind of creation.
Thanks.
Suite Creation
Re: Suite Creation
once you turn on suites, the whole system need to have a Guest Number and a Multioccupation number which is generally the main room number, not all that hard as long as you have enough numbers!
Re: Suite Creation
Hi!!!
And the guest number, where do I get it, or generat it?
Best regards
Best regards
Best Regards
Jose Alves
Jose Alves
Re: Suite Creation
After some research on Alcatel business portal I have locate the solution. The guest number is a analog extension with no physic allocation ( shelf, board, coupler)
Is a room type and is a guest mode.
Best Regards
Jose Alves
Jose Alves
