Prohibit the entry into third during a communications
got
Post by got »
hello
I created IP Phone, unfortunately the Override feature is enabled.
so people can imixer in other communications.
it is very disagreeable.
can you tell me how to prevent entry into thirds?
thank you
Re: Prohibit the entry into third during a communications
In user - you have Phone feature COS.
In COS/ Phone feature COS - you can:
- disable intrude for calling set - Suffxes - Intrude=0
- or, disable intrude for called set - Rights - protection again set inrude=1
So with phone feature COS you can manage 3 level architecture:
1 - Big Boss - have protection/ allowed suffix
2 - Boss - no protection/ allowed suffix
3 - usual users - no protection/ disabled suffix
got
Post by got »
Thank you to all
I had to change the value of the category of telephone operation. I put 1 instead of 0
You need to manage phone COS (COS/ Phone feature COS)
If you want to disable entry for calling set - in phone feature COS - item Suffixes/ Intrude=0
If you want to protect from entry called set - in phone feature COS - item Rights protected against set intrude=1
F.e. if you need to prohibit the entry for all users - manage this in Phone feature COS 0 and not necessary to change Phone feature COS in user parameters.
If you need to prohibit the entry for some users - manage this in another Phone feature COS (f.e. 1) and change Phone COS in user parameters.
Return to “IP”
