Can't create new virtual terminal
L_lefante
Post by L_lefante »
I can't create new virtual terminal. Do you know if there is some restriction regarding this?
When I attempt to create a new one an error pop up shows saying "Maybe the limits of subscribers is reach" (attached there is a screen shot)
Re: Can't create new virtual terminal
I think there is a license limit. Check your licenses
L_lefante
Post by L_lefante »
Hi cavagnaro, thanks for you reply.
License for virtual terminal?
I can create DECT and IP without problem, so I assume is not a general limit problem.
Maulwurf
Post by Maulwurf »
you do not need license für virtual sets in oxo.
Check your global system limits. Check your internal numberung plan (numbers free?).
L_lefante
Post by L_lefante »
System limits shows 31 used (219 free and 250 max).
There are enough free subscriber number in numbering plan.
Return to “Configuration”
