Pcscopy failed
Alcatel_lbt
Pcscopy failed
Post by Alcatel_lbt »
Hello all,
I'm trying to install PCS card for redundancy on OXE. On PCS card, I configured IP, trusted host, created empty database and reboot it.
Then I configured via MGR the PCS on the CS Main. But when I try to use pcsopy on the CS Main to copy the database to the CS, copy fails. CS cards ask me several time the swinst password of PCS card (same error if I field it or not).
Looking at the trafic, SSH connection is established between both card. CS card creates the PCS database files but it seems to fail to send it.
Firmware used is the same on both cards (R10.1.1).
Do you have any idea on this issue ??
Thank you in advance
Gilles
oldboy
Re: Pcscopy failed
Post by oldboy »
Have you put the PCS address in the hosts file of the CS?
What state is the PCS after you rebooted it, is the TEL stopped?
Alcatel_lbt
Re: Pcscopy failed
Yes PCS is already in host file of the CS card (as 47xx device).
PCS is running, TEL is started.
I have this message when pcscopy failed:
"End NOK: Restore on PCS failed"
Console message: "Database update: error 6 info -1"
I also try to deactivate SSH.
Comportment is a bit different (I don't have several prompt asking the swinst PCS pwd), and error is not exactly the same:
"End NOK: Copy on PCS failed"
Console message: "Database update: "error5 info 0"
Thank you for your support
Gilles
oldboy
Re: Pcscopy failed
Post by oldboy »
Stop the TEL and try again!
Give me remote access and i will have a look for you for a small fee :D
Alcatel_lbt
Re: Pcscopy failed
I tried to stop the TEL, but it's still KO.
I think the problem is about the swinst password required when the PCS copy is launched. Process is not able to copy the database on PCS...
And PABX is connected to a closed network, unaccessible on the Internet...
oldboy
Re: Pcscopy failed
Post by oldboy »
I have never seen that the swinst password is ever required.
Alcatel_lbt
Re: Pcscopy failed
I finally found the mistake. I declared PCS IP as 47xx in trusted host files, but it must be declared as CPU.
Thank you
Gilles
byronwak
Pcscopy failed
Post by byronwak »
I have upgrade to 8.01 and i cannot access administration page.
When i put the password i get the authentication failed message.
I can reset the password?
oldboy
Re: Pcscopy failed
Post by oldboy »
byronwak wrote: 14 May 2019 16:35 I have upgrade to 8.01 and i cannot access administration page.
What admin page?
Return to “Passive Communication Server”
