Removing a user
stestar
Removing a user
Post by stestar »
I've problems to remove a user in the "User Management" area in category "Provisioning".
In the Action column i've only a link to modify a user. There is no button to remove a user.
Do you have the possibility to delete users in this area?
The following profiles are assigned to my admin account: administration, configuration, XMLFwManagement, Monitoring
Do I need an additional right?
Best regards,
Stephan
Split
Re: Removing a user
Post by Split »
Select the user and use the rubber Icon ( over modify ) to delete the user
