IP Touch 4038 / Stuck with all lights on at startup
IP and Voice over IP
poypoy
Post by poypoy »
I'm facing a weird issue today with an Alcatel Phone IP Touch 4038. Phone restarted and get stuck with all leds on and a blank screen. It doesn't boot at all. I've tried to connect it with an electrical powerplug instead of the PoE and still the same.
Is it a way to reset this phone or resend the FirmWare?
Thanks for your suggestions.
PoY
Re: IP Touch 4038 / Stuck with all lights on at startup
Search the forum for similar issues. If don't remembar bad was a memory issue on some devices
poypoy
Post by poypoy »
Got it! seems to be a kind of memory trouble....
viewtopic.php?f=18&t=23327&p=84065&hili ... uch#p84065
So, what's next? If out of warranty, nothing else can be done?! They are only supported for 1 or 2 years of warranty... I'm so disappointed. :(
Open an esr and check
poypoy
Post by poypoy »
Directly to Alcatel? How shall I proceed?
sorry for my dumb question, but I've asked my provider: NextiraOne and as the devices are 4 years old, nothing else will be done.
The only thing interesting that the engineer told me is that another customer had the same issue. He changed the device and kept the other one. Few months after, he took it back as it forgot if it was really broken or not and it worked again like a charm.
Really curious. Kind of defect on this series.
Anyway, thanks a lot for your lights and for your time. I really appreciate :)
poy
Return to “IP / VoIP”
