OmniSwitch OS650-10L Flash corrupt
Ruheal Maqsood
Post by Ruheal Maqsood »
I have a OS6450-10L which is not working fine.. As i am also a new user on A-Lucent platform So please guide me. Here is the console output of the switch. :(
AOS BootSelector Version: 6.6.3.259.R01
Creation Date: Mar 21 2012 23:07:59.
Press x to choose XMODEM...
Press s to STOP AT MINIBOOT...
Reading kfminiboot.bs from /boot ...done:
1452091
Uncompressed kfminiboot.bs @ 0xA10000...
Running Miniboot...
Detected board DB-98DX4122-48G
Ctrl env init... Done.
CPU if init..... Done.
Done. Actual freq = 96153Hz
Memory on board initialized .
Init Phy port 0 .. Done
Init Phy port 1 .. Done
Power up GMII port0 .. Done.
Power up GMII port1 .. Done.
Detected DRAM size 256MB
Detect SysClk 320MHz
Detect Tclk 200MHz
Marvell Controller initialization Done.
Eth int Ctrl.... Done
GPIO int Ctrl... Done
PEX int Ctrl.... Done
PEX0 init....... Done. DEVICE type selected
USB Init........ Done
USB int Ctrl.... Done
XOR int Ctrl.... Done
XOR init........ Done
mvCtrlInit2..... done
PCI auto config. done
sysHwInit2...... DoneUSB2 Host Stack Initialized.
USB Hub Driver Initialized
USBD Wind River Systems, Inc. 560 Initialized
Non-PCI USB device found: pgmIf=0xa0, idx=0 , baseAddr=0xf1050100, irq=19, swapF
unc=0xa1abf4
EHCI Controller found.
Waiting to attach to USBD...Done.
0xffffe50 (tRootTask): usbBulkDevInit() returned OK
usbCbiUfiDevInit() returned OK
CBI Class Driver Successfully Initialized
CS EEPROM Module ID: 420122b3 , System type: Lite 6450 8 POE ports, 2 combo port
s & 2 fixed sfp stacking or uplink port - Kingfisher2
System Configuration
BSP Ver: 1.2/1.1.01 Creation date: Mar 22 2012, 00:07:53
CHIP : MV88F6281 Rev 2
CPU : ARM926 (Rev 1)
BOARD : DB-98DX4122-48G (0x7)
CLOCKs : tClk = 200 MHz, sysClk = 320 MHz
pClk = 800 MHz
NAT_SUPPORT = Disabled
VFP_SUPPORT = Disabled
FlashFX initialization required 799ms
File System initialization required 0ms
FlashFX initialization required 99ms
Target Name: vxTarget
Ethernet port #0 initialized
mgi0 Interface Loaded
mgi0 Interface Started
mgi0 Interface - Link Up, 1000 Full
Attaching network interface lo0... done.
Adding 8031 symbols for standalone.
Boot parameters are:
'flash(0,0)cmm:default e=10.4.50.165:ff000000 g=10.4.50.5 u=admin pw=switch cb=
9600 cp=none cs=1 cw=8 cm=modemControlOff'
AOS miniboot version: 6.6.3.259.R01
VxWorks (for DB-98DX4122-48G BE MMU ARCH 5) version VxWorks5.5.1
KERNEL: WIND version 2.6
Made on Mar 22 2012, 00:07:53.
Copyright Wind River Systems, Inc., 1984-2006
CPU: DB-98DX4122-48G BE MMU ARCH 5. Processor #0.
Memory Size: 256 MBytes. BSP version 1.2/1.1.01.
Portions of code copyrighted by Alcatel Internetworking, Inc. 1994-2012. All Ri
ghts reserved
Portions of code copyrighted by Apptitude, Inc. 1997-1999. All Rights reserved
Portions of code copyrighted by Free Software Foundation, Inc. 1989,1991. All r
ights reserved
Portions of code copyrighted by The OpenLDAP Foundation 1999-2000. All rights r
eserved
Portions of code copyrighted by Theodore T'so 1994,1995,1996,1997,1998,1999. Al
l Rights reserved
Portions of code copyrighted by RSA Security, Inc. All Rights reserved
Portions of code developed by the Carnegie-Mellon University.
Attempting to load from the CERTIFIED directory...
Loading kernel from '/flash/certified/KFos.img'...
Cannot find component(alcatelNetworking_kernel.lnk) in package(/flash/certified/
KFos.img)!
Cannot find component(kernel.lnk) in package(/flash/certified/KFos.img)!
Unable to load kernel image from file '/flash/certified/KFos.img'.
Unable to boot from the CERTIFIED software release.
[Miniboot]->USB Disaster Recovery Activated
sysUsbDisasterRecoveryTask: ERROR: /uflash not found
[Miniboot]->
[Miniboot]->
devnull
Re: OmniSwitch OS650-10L Flash corrupt
Post by devnull »
Easiest: prepare a (switch recognized) USB stick (test with "usb enable" "cd /uflash" "dir" on other switch)
create directory 6450 on stick
create directory certified inside /6450 on stick
copy AOS Image files to /6450/certified
plug in usb stick
reboot switch (watch console)
alternative see:
viewtopic.php?f=394&t=20639
ChrisG
Post by ChrisG »
I need the firmware for OS6250-8M,
help me
Return to “OmniSwitch 6450”
