Spanning tree error between 2 switch OS6424UD
cavangboi
Post by cavangboi »
Please help me to solve this problem when connect 2 OS6424UD switch with different version of software:
Switch 1: DC 6.4.3.520.R01 GA
Switch 2: OS6400-UD24 6.4.5.402.R02 GA
This is diagram that I get trouble with spanning tree.
Router Cisco 7606------port1/4_Switch 1_port 1/10 ----------port1/1_ Switch 2
all vlan in Switch 1 cannot reach to Switch 2.
Switch 1, I enter command :show spanning tree ports
Switch1# show spantree ports
Vlan Port Oper Status Path Cost Role Note
1 1/2 DIS 0 DIS
1 1/5 DIS 0 DIS
1 1/6 DIS 0 DIS
1 1/7 DIS 0 DIS
1 1/8 DIS 0 DIS
1 1/9 DIS 0 DIS
1 1/11 DIS 0 DIS
1 1/12 DIS 0 DIS
1 1/13 DIS 0 DIS
1 1/14 DIS 0 DIS
1 1/15 DIS 0 DIS
1 1/16 DIS 0 DIS
1 1/17 DIS 0 DIS
1 1/18 DIS 0 DIS
1 1/19 DIS 0 DIS
1 1/20 DIS 0 DIS
1 1/21 DIS 0 DIS
1 1/22 DIS 0 DIS
1145 1/10 LIST 4 DESG Disputed
3996 1/4 FORW 4 ROOT Disputed
3996 1/10 LIST 4 DESG Disputed
Switch2# show spantree ports
Vlan Port Oper Status Path Cost Role Loop Guard Note
1145 1/1 FORW 4 DESG DIS
1145 1/2 DIS 0 DIS DIS
1145 1/3 DIS 0 DIS DIS
1145 1/4 DIS 0 DIS DIS
1145 1/5 DIS 0 DIS DIS
1145 1/6 DIS 0 DIS DIS
1145 1/7 DIS 0 DIS DIS
1145 1/8 DIS 0 DIS DIS
1145 1/9 DIS 0 DIS DIS
1145 1/10 DIS 0 DIS DIS
1145 1/11 DIS 0 DIS DIS
1145 1/12 DIS 0 DIS DIS
1145 1/13 DIS 0 DIS DIS
1145 1/14 DIS 0 DIS DIS
1145 1/15 DIS 0 DIS DIS
1145 1/16 DIS 0 DIS DIS
1145 1/17 DIS 0 DIS DIS
1145 1/18 DIS 0 DIS DIS
1145 1/19 DIS 0 DIS DIS
1145 1/20 DIS 0 DIS DIS
1145 1/21 DIS 0 DIS DIS
1145 1/22 DIS 0 DIS DIS
1145 1/23 DIS 0 DIS DIS
1145 1/24 DIS 0 DIS DIS
3996 1/1 FORW 4 DESG DIS
Switch 1 # show system
System:
Description: Alcatel-Lucent 6400 24 FIBER PORTS W/STK DC 6.4.3.520.R01 GA, April 08, 2010.,
Object ID: 1.3.6.1.4.1.6486.800.1.1.2.1.10.1.4,
Up Time: 1 days 16 hours 42 minutes and 5 seconds,
Contact: Alcatel-Lucent, http://alcatel-lucent.com/wps/portal/enterprise,
Services: 72,
Date & Time: WED JUN 04 2014 06:45:05 (GMT)
Flash Space:
Primary CMM:
Available (bytes): 65556480,
Comments : None
Switch 1#show hardware info:
CPU Type : PowerPC 8248,
Flash Manufacturer : Spansion, Inc.,
Flash size : 134217728 bytes (128 MB),
RAM Manufacturer : Samsung,
RAM size : 268435456 bytes (256 MB),
Uboot Version : 6.4.3.479.R01,
Miniboot Version : 6.4.3.479.R01,
Product ID Register : 03
Hardware Revision Register : 30
FPGA Revision Register : 10
Switch1#show configuration snapshot ( spanning tree and vlan stacking section only )
! Spanning tree :
bridge mode 1x1
! VLAN STACKING:
ethernet-service svlan 1145 nni 1/10
ethernet-service svlan 3996 nni 1/4
ethernet-service svlan 3996 nni 1/10
________________________________
Switch 2# show system:
System:
Description: Alcatel-Lucent OS6400-UD24 6.4.5.402.R02 GA, December 24, 2012.,
Up Time: 0 days 1 hours 57 minutes and 24 seconds,
Services: 72,
Date & Time: WED JUN 04 2014 02:29:52 (GMT)
Flash Space:
Primary CMM:
Available (bytes): 61038592,
Comments : None
Switch2 # show hardware info:
System:
Services: 72,
Flash Space:
Primary CMM:
Comments : None
Switch2#show configuration snapshot ( spanning tree and vlan stacking section only )
! Spanning tree :
bridge mode 1x1
! VLAN STACKING:
I troubleshoot temporarily by disable spanning tree in Switch 2:
Switch 2# ethernet-service svlan 3996 1x1 stp disable
Switch 2# ethernet-service svlan 1145 1x1 stp disable
but i still don't understand what cause this problem ?
Sorry for my bad English.
cavangboi
Re: Spanning tree error between 2 switch OS6424UD
to your config: are you sure that you need vlan-stacking (= QinQ) in your network? Or did you looked for tagging (= 802.1q)?
The reason for the disputed state is descriped in this techtip:
Disputed state in show spantree port Output ( Tip #6249 )
Problem Description / Symptom
Show spantree <vlan> ports output displays port as disputed and port state is "LIST"
Background
A port in STP will be in "Disputed" state, when a port which is receiving an inferior STP BPDU(low priority) even in learning state. Meaning even after a switch sends a higher priority BPDU if it keeps receiving a lower priority STP BPDU then that port will move to "Disputed" state and will be in "Listening" state. So at this point of time there will no traffic allowed through this port "show vlan port" CLI, which will be in blocking state. But this will not make the port link go down only the VLAN will be in blocking state
Solution / Workaround
We can either "Filter" BPDU in the port or shutdown the port if a BPDU is received with the following command.
-> policy port group UserPorts <slot/port>
-> qos user-port <filter/shutdown> bpdu
-> qos enable
-> qos apply
You see both vlans are blocked at 1/4 and 1/10.
hope that will help you
cavangboi
Post by cavangboi »
Thank you very much Silvio.
I need vlan-stacking (= QinQ) in my network. For more infomations: when I connect 2 OS6400 with 6.4.3.520.R01 GA sofware, all thing working fine, no spanning tree eror. So maybe the eror come from the diferent in OS6400 sofware ?
cavangboi
the different images are no problem.
But it's always recommended to have the same software in all your switches. Also GA-Software isn't a good choice. this is the first released image of a version. So you should look for an update of your switches to an actual maintanance release.
Your proble are the disputed mode of the ports. Look in my last post for the reason.
cavangboi
Post by cavangboi »
Dir Silvio !
all switchs in my network are in used so I don't want to change images. Updating images maybe a big trouble to me ( also stopping Internet service to my customer in the province ).
thank you any way !
best regards
cavangboi
Return to “OmniSwitch 6400”
