Anonymous UDA Web Search
dizfunkshinal
Post by dizfunkshinal »
Hi all,
This seems like it should be available and I'm just missing it somehow.
Is there a way for users to access a web page and perform a search of UDA?
My installation is a MyIC-Lync integration and the MyIC "shim" doesn't have any ability to search UDA. When I log in to telephony, I can search a directory there, and it works well. I'm looking for a webpage/url that I can send users to so they can look-up user's extensions.
Let me know if this exists and I'm just missing it.
Thank you, in advance, for you guidance!
Re: Anonymous UDA Web Search
No. There is no such as those are OXE extensions already and you can find them by searching on the keyboard or using some MyPhone client.
dizfunkshinal
That's what I was afraid of, thank you for the quick response!
