OS6400 POE PORTS NOT WORKING
mramirezg
Post by mramirezg »
Hi, we have an OS6400P48 with release 6.4.3.609.R01 with 510 Watts power supply
There are IP Touch phones connected with PoE and suddenly PoE stops working, ports with PC´s connected are working OK.
If we reboot the switch the PoE works fine. But after 2 or 3 days happens the same
The switch is working in stack with another 6400P48, the switch with the problems is stack 2, switch stack 1 has no problems.
I´m attaching the logs of the switch
Can anyone help us
Mauricio
devnull
Re: OS6400 POE PORTS NOT WORKING
Post by devnull »
Can't read anything out of the log files, as theses are no cleartext files
I would (as always) upgrade to the latest code (6.4.4.669 or 6.4.5.516) and see whether this fixes anything
Return to “OmniSwitch 6400”
