Backup CS2 in CS
bianquiviry
Backup CS2 in CS
Post by bianquiviry »
I'm trying to upload a backup of extracted cs2 a CS but I get message invalid file, my question is: I load a backup extracted on CS2 in a CS?
Murphy72
Re: Backup CS2 in CS
Post by Murphy72 »
how do you save / restore the database ?
If you do a backup of mao etc. on harddisk via swinst you can restore these files to another cs.
CS2 Backup on Harddisk -> get the Backup via ftp -> put the Backup on CS, restore from Harddisk, finished.
Important: the CS should have the same softwareversion or higher than the CS2, you cannot restore a
database to an older softwareversion.
The last thing is, that the cpu-id in the license-key of the database is different to your new cpu-id.
bianquiviry
Hi Murphy,
that's the procedure I am following and I have done it`s so many times with no problems, I'm going to try once more time, I charge the version of the software and is the same. I say if I can do it
Thank you so much
Regards!
oldboy
Post by oldboy »
When you ftp'd it off did you do it in binary or on for that fact was it binary as well? has it changed the name of the file??? like to CAPITALS MAO or MAO-ACC???
oldboy
Post by oldboy »
So is it resolved?
Can you copy a full log of what you are doing ?
bianquiviry
Hi Frank,
I was loading the backup in binary instead of ascii for this not working.
thanks so much for your answers and your attention
bianquiviry
Hi Oldboy
I was doing the backup load in binary and not ascii, it was my mistake.
thanks for your replys.
bianquiviry
a pleasure to greet him, I'm having some problems with my software, initially worked smoothly after different loads in different pbx I began to notice that I had problems with DHS3ext directory, solve copying the missing files to the directory. now note that when attempting to lift a trunk sip DHS3bin get errors in directory, I guess when I charge the full software directories teransfiere not, let me know what is happening in that software load since I have been doing in the same way ever, and by the end tells me OK. however still incomplete transferring directories, I downloaded the software several times in the Business Portal, and the result is the same. I apologize for my bad drafting.
