problem with windows 8
paolo41
Post by paolo41 »
I have a problem when i'm trying to connect to the switchboard OMNIPCX OFFICE R6 via the programm OMC R 610. I can't connect to the switchboard but this happens only on windows 8 (when i am trying on windows xp everything is ok).The ip address on switchboard is 192.168.92.246 and my ethernet card is 192.168.92.245.The connection cable is crossover (the same as windows xp).Moreover there is a yellow sign in the ethernet icon on the taskbar of the pc.Anyone who can help me??? Thank you in advance.
enio.eltz
Re: problem with windows 8
Post by enio.eltz »
OMC 610 is not compatible with W8. You must use OMC 920.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
