How to add Local Mobile Number to the System
shahin
Post by shahin »
Hello ,
How can i add the Local Mobile Number With Corresponding Name to PBX to show in the Report ,so it will be very easy for Department to check....
Thank you...
Re: How to add Local Mobile Number to the System
abreviated number
can you please explain more what's you scope : report is for accounting?
shahin
Post by shahin »
Sure..
When i creating the Daily Telephone Report it showing the Mobile numbers ,most of them are Staff Mobile Number ..If i add the Mobile Number to the System i can see the Name of the staff .. Just feeding the Information ...
you have already predefined report for speed dilaing N° but i don't think that you could got the name of called party in your report even if you use spd ;
if you haven't lot of mobiles you can add them as region in carrier parameter and in report you use called region filter
for me i have more than 900 mobile in form of float so when i could one of them i got called region AMAfloat
You could look as alternative to CUG feature or REX as alternatives and consider the advantages or disadvantages regarding also features.
Return to “Phone Book”
