I'm testing the SLB function of Omniswitch 9702E.
I configure in the omniswitch like that:
ip slb admin enable
ip slb cluster "GAD" vip 172.16.0.25
ip slb server ip 172.16.0.23 cluster "GAD"
ip slb server ip 172.16.0.24 cluster "GAD"The real NIC is configured as:
172.16.0.23/24, no GWCode: Select all
172.16.0.25/24, GW 172.16.0.1I check and see that:
1. After create SLB, Switch appear a new Static mac-address:
GAD# show arp
Total 26 arp entries
Flags (P=Proxy, A=Authentication, V=VRRP)
IP Addr Hardware Addr Type Flags Port Interface Name
172.16.0.24 00:9c:02:ad:96:56 DYNAMIC 2/16 vlan 12
172.16.0.25 e8:e7:32:67:66:60 STATIC P UNKNOWN vlan 12
172.16.0.41 a0:b3:cc:df:df:d8 DYNAMIC 2/13 vlan 12
2. Microsoft loopback have mac-address: 02-00-4C-4F-4F-50 associated with IP 172.16.0.25
I'm note sure i configured these NIC card right.
Could you please check if where is my fault?
Thanks and best regards,
dangkita
