oaw-ap61 with newer model controller
Also known as OmniAccess Instant AP
afam0us
Post by afam0us »
hello all,
have anyone can confirm and tested which of the new model wlan controller still support oaw-ap61? :?
any answer is much appreaciate :)
devnull
Re: oaw-ap61 with newer model controller
Post by devnull »
From release notes of AOS-6.3 it states that it supports AP61, so i guess it should.
I have no AP61 here to test but i believe it should be software dependent, not based on controller hardware.
LicaFronte
Post by LicaFronte »
Is it safe to use in pc?
devnull
Post by devnull »
AP61/AP62/AP70/RAP2/RAP5 will not be supported with AOS 6.4, hence you can't upgrade your controller to AOSW-6.4 (e.g. for AP275) without loosing your old APs.
@ Lica: What do you mean?
Return to “OmniAccess Wireless Access Points”
