I'm checking one of our customer installed base using OXE Crystal, there are reported issue and also I confirmed that when I do an ALL INSTANCE in USER Parameter I get slow response from OXE. I waited for more than 3 minutes when it suddenly displayed all extensions.
I tried to check the incvisu and I found this error: 19/02/14 11:28:54 000001M|---/--/-/---|=2:2677=Maoagent : Exception 11, operatio
n GET, object SUBSCRIBER, PC = 0x08448f44.
Also we found out that the Omni Vista cannot sycnchronized with OXE anymore.
Anu possible reason this is happening?
Thanks in advance.
Jonnel
USER Parameter Hang/Slow Response
- jonnel_ponesto
Re: USER Parameter Hang/Slow Response
HD ? CPU is OK based on customer installed base? Meaning... He may have increased users and so but never the CPU.
Check DB consistency
- jonnel_ponesto
Hi Cavagnaro,
Appreciate the reply, we downloaded the mao file from site and have it simulated in our lab. we'll consider also the DB consistency.
Thanks,
Jonnel
Thanks,
Jonnel
- frank
I would first do a backup.
Then check the database:
cdmao
checkdb
Rebuild the database and dictionary:
cdmao
fichges -force_recover_dico
Then do a full CPU duplication, and a double bascule.
Before you do anything, clear the backtraces with
increset
5
then do the manipulation again.
do excvisu after, and see if you have a backtrace.
if you do, then you are entitled to open a case with Alcatel-Lucent
cdmao
checkdb
cdmao
increset
5
- jonnel_ponesto
Hi Frank,
Appreciate your inputs I'll check this procedure and get back to you.
For now we cannot open a case to ALU because customer's OXE has an expired SMS. Sales team is negotiating the SPS offer to the client.
Jonnel
Jonnel
- jonnel_ponesto
Hi Frank,
Unfortunately I'm still having the issue. We will just reload an old backup and restore it onsite.
Thank you,
Jonnel
Thank you,
Jonnel
- frank
Hi ,
You can still open a case with ALU if you have a certified engineer, and if the release is supported.
