Errors and incidents 1609 & 3853 on R5.0Ux-d2.313-7-b-gr-c5s
wizzy
Post by wizzy »
During boot of R5.0Ux-d2.313-7-b-gr-c5s2 on a CPU6 I have the following errors :
timed run as effective root user-id.
29/06/07 07:28:09 000001I|00/28/-/---|=4:0260=Beginning of downloading binio1n
29/06/07 07:28:16 000001I|00/28/-/---|=5:0261=End of downloading binio1n
29/06/07 07:28:16 000001I|00/28/-/---|=4:0260=Beginning of downloading tonesnv
29/06/07 07:28:16 000001I|00/28/-/---|=5:0261=End of downloading tonesnv
29/06/07 07:28:16 000001M|--/--/-/---|=5:2009=Initialisation CPU role MAIN
(000226:000017) dl_id 8 appli_cap.ui 77825
(000226:000018) dl_id 34 appli_cap.ui 77825
(000226:000019) dl_id 83 appli_cap.ui 77825
(000226:000020) dl_id 84 appli_cap.ui 77825
(000226:000021) dl_id 94 appli_cap.ui 77825
spbmgr: The SPB board has not been detected
Command "SPBMGR" (pid 397) exited with status 1.
(000257:000022) Illegal coupler-type
(000257:000023) Dump: .04.03.0d.00.02.00.00.04.00.fe.f9.00.01
29/06/07 07:28:20 000001M|--/--/-/---|=0:1603=IO1 driver error, wrong telephone msg received, line 4793, length 13
29/06/07 07:28:20 000001M|--/--/-/---|=3:1607=04.03.0d.00.00.00.00.04.00.fe.f9.00.01.ff.ff
--> ACCOUNTING 0 tickets stored in database
29/06/07 07:28:29 000001M|--/--/-/---|=0:1625=4615 driver : data transmission problem number 5
29/06/07 07:28:29 000001M|00/28/-/---|=4:0260=Beginning of downloading bnvdsp0cpu6
29/06/07 07:28:29 000001M|00/28/-/---|=5:0261=End of downloading bnvdsp0cpu6
29/06/07 07:28:29 000001M|00/28/-/---|=4:0260=Beginning of downloading bnvdsp1cpu6
29/06/07 07:28:30 000001M|00/28/-/---|=5:0261=End of downloading bnvdsp1cpu6
29/06/07 07:28:33 000001M|00/28/-/---|=2:3853=Message buffer full (Inc 3 File 39 Line 408 Stat1 0)
29/06/07 07:28:34 000001M|00/28/-/---|=2:3853x072=Message buffer full (Inc 3 File 39 Line 408 Stat1 0)
29/06/07 07:28:34 000001M|00/28/-/---|=2:3853=Message buffer full (Inc 3 File 39 Line 408 Stat1 0)
29/06/07 07:28:34 000001M|00/28/-/---|=2:3853x024=Message buffer full (Inc 3 File 39 Line 408 Stat1 0)
29/06/07 07:28:54 000001M|--/--/-/---|=0:1609=2098 incidents sent by coupler (0, 28)
29/06/07 07:28:54 000001M|00/28/-/---|=2:3853=Message buffer full (Inc 3 File 39 Line 408 Stat1 0)
29/06/07 07:30:30 000001M|00/28/-/---|=2:2457=IO1 coupler (0,28) not initalized yet
The incidents 1609 & 3853 are repeated almost every 5 seconds but the system works fine. I am also a little worried about incident 2457.
These incidents appeared only when I restore the OPS files
et
Re: Errors and incidents 1609 & 3853 on R5.0Ux-d2.313-7-b-gr-c5s
Post by et »
May be you have wrong CPU type in OPS files? For example, CPU3 instead of CPU6.
(000257:000022) Illegal coupler-type - may be this?
wwoohhaaa, I would open a ticket with France for this, if
CPU duplication
System shutdown
System restart
does not fix it ..
Eliott_DUP
Post by Eliott_DUP »
wizzy wrote:
ACT--------------------------------------------------------------^  ^     ^
Board---------------------------------------------------------------'     '
Terminal------------------------------------------------------------------'
Which board is plugged at position 0-4?
Post the results of:
config 0
uhwconf
cplstat 0 28
and try
rstcpl 0 6 or 0 20 (CPU position) to reset IO1
Boobalan Subramani
Post by Boobalan Subramani »
We got the same error while running t3
Illegal coupler-type 0
Illegal physical terminal
Site has one way audio for all incoming and outgoing calls after power failure.
Return to “GENERAL”
