Is there a command I'm missing to enable these?
I'm just trying to use the sfp ports as uplinks.
I've got 2 6450 switches, and each has an sfp fiber transceiver in port 1/49
Any help is greatly appreciated.
sw1:
-> show configuration snapshot
! Stack Manager :
! Chassis :
system name sw1
system location sw1
system daylight savings time enable
! Configuration:
! VLAN :
vlan 1 disable name "UNUSED"
vlan 5 enable name "DATA"
vlan 5 port default 1/49
vlan 55 enable name "MGMT"
vlan 55 port default 1/44
vlan 99 enable name "limbo"
vlan 99 port default 1/1
vlan 99 port default 1/2
vlan 99 port default 1/3
vlan 99 port default 1/4
vlan 99 port default 1/5
vlan 99 port default 1/6
vlan 99 port default 1/7
vlan 99 port default 1/8
vlan 99 port default 1/9
vlan 99 port default 1/10
vlan 99 port default 1/11
vlan 99 port default 1/12
vlan 99 port default 1/13
vlan 99 port default 1/14
vlan 99 port default 1/15
vlan 99 port default 1/16
vlan 99 port default 1/17
vlan 99 port default 1/18
vlan 99 port default 1/19
vlan 99 port default 1/20
vlan 99 port default 1/21
vlan 99 port default 1/22
vlan 99 port default 1/23
vlan 99 port default 1/24
vlan 99 port default 1/25
vlan 99 port default 1/26
vlan 99 port default 1/27
vlan 99 port default 1/28
vlan 99 port default 1/29
vlan 99 port default 1/30
vlan 99 port default 1/31
vlan 99 port default 1/32
vlan 99 port default 1/33
vlan 99 port default 1/34
vlan 99 port default 1/35
vlan 99 port default 1/36
vlan 99 port default 1/37
vlan 99 port default 1/38
vlan 99 port default 1/39
vlan 99 port default 1/40
vlan 99 port default 1/41
vlan 99 port default 1/42
vlan 99 port default 1/43
vlan 99 port default 1/45
vlan 99 port default 1/46
vlan 99 port default 1/47
vlan 99 port default 1/48
vlan 99 port default 1/50
! VLAN SL:
! IP :
ip service all
ip interface "MGMT" address 192.168.55.2 mask 255.255.255.0 vlan 55 ifindex 1
ip interface "DATA" address 192.168.5.2 mask 255.255.255.0 vlan 5 ifindex 2
! IPMS :
! AAA :
user password-policy cannot-contain-username enable
! PARTM :
! 802.1x :
! QOS :
! Policy manager :
! Session manager :
session timeout cli 20
! SNMP :
! RIP :
! IPv6 :
! IP multicast :
! IPRM :
ip static-route 192.168.75.0/24 gateway 192.168.55.35 metric 1
ip static-route 0.0.0.0/0 gateway 192.168.5.1 metric 1
! RIPng :
! Health monitor :
health threshold temperature 78
! Interface :
interfaces transceiver ddm enable
! Udld :
! Port Mapping :
! Link Aggregate :
! VLAN AGG:
! 802.1Q :
! Spanning tree :
bridge mode 1x1
! Bridging :
! Bridging :
! Port mirroring :
! UDP Relay :
! System service :
swlog console level info
! SSH :
! VRRP :
! Web :
! AMAP :
! Lan Power :
! NTP :
! RDP :
! VLAN STACKING:
! EFM-OAM :
! SAA :
! Loopback-detection :
! ERP :
! TEST-OAM :
! DHL :
! LLDP :
! DHCP Server :
! Stack Split-Protection Helper :
sw2:
! Stack Manager :
! Chassis :
system name sw2
system location sw2
! Configuration:
! VLAN :
! VLAN SL:
! IP :
ip service all
ip interface "MGMT" address 192.168.55.3 mask 255.255.255.0 vlan 55 ifindex 1
ip interface "DATA" address 192.168.5.3 mask 255.255.255.0 vlan 5 ifindex 2
! IPMS :
! AAA :
! PARTM :
! 802.1x :
! QOS :
! Policy manager :
! Session manager :
! SNMP :
! RIP :
! IPv6 :
! IP multicast :
! IPRM :
ip static-route 192.168.75.0/24 gateway 192.168.55.35 metric 2
! RIPng :
! Health monitor :
! Interface :
! Udld :
! Port Mapping :
! Link Aggregate :
! VLAN AGG:
! 802.1Q :
! Spanning tree :
bridge mode 1x1
! Bridging :
! Bridging :
! Port mirroring :
! UDP Relay :
! System service :
! SSH :
! VRRP :
! Web :
! AMAP :
! Lan Power :
! NTP :
! RDP :
! VLAN STACKING:
! EFM-OAM :
! SAA :
! ERP :
! TEST-OAM :
! DHL :
! LLDP :
! DHCP Server :
